[fdo][FDO310][Modified] modifying an existing Value List constraint on a property ra...
Brent Robinson
brent.robinson at autodesk.com
Wed Nov 29 12:57:18 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO310
Type:
Defect
Artifact ID:
FDO310 (modifying an existing Value List constraint on a property raises an unhandled exception)
Modified by:
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO310: Do not free const strings returned by FdoDataValue::ToString().
Modified
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintList.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintList.cpp?view=diff&rev=555&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintList.cpp&r1=554&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintList.cpp&r2=555
File: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintRange.cpp https://fdocore.osgeo.org/source/browse/fdocore/branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintRange.cpp?view=diff&rev=555&p1=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintRange.cpp&r1=554&p2=branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/PropertyValueConstraintRange.cpp&r2=555
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
