[fdo][FDO214][New] Schema Reverse-Engineering fails if foreign key named the sa...
Brent Robinson
brent.robinson at autodesk.com
Fri Oct 13 12:15:20 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO214
Type
Defect
Artifact ID
FDO214 (Schema Reverse-Engineering fails if foreign key named the same as column.)
Reported by
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
New artifact details:
- Summary set to new value
- Subcomponent set to new value
SCHEMA
- Steps to Reproduce set to new value
- Create a MySql database without FDO MetaSchema
- Create table1 with single primary key unsigned int column named "id" (use InnoDB storage engine )
- Create table2 with single primary key unsigned int column named "id", plus another unsigned int column called "table1_id" (use InnoDB storage engine)
- Add foreign key named table1_id to table2 with columns table2.table1_id and table1.id
- Open the datastore in FDO and did a DescribeSchema.
The DescribeSchema fails with a duplicate entry 'table1_id" message.
- Artifact created
- Version set to new value
V2
- Artifact Status set to new value
New
- Platform set to new value
All
- Operating system set to new value
All
- Description set to new value
Performing a DescribeSchema, on a MySQL datastore without MetaSchema, fails if a table has a column and foreign key with the same name.
An exception with "duplicate entry" message is thrown.
- Component set to new value
RDBMS
- Defect Severity set to new value
High
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
