[fdo][FDO214][User] Schema Reverse-Engineering fails if foreign key named the sa...
Brent Robinson
brent.robinson at autodesk.com
Fri Oct 13 12:15:52 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO214
Type:
Defect
Artifact ID:
FDO214 (Schema Reverse-Engineering fails if foreign key named the same as column.)
Modified by:
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
The following modifications were made to this artifact:
-- New value added to attribute Reviewer:
barbarazoladek
-- New value added to attribute Assigned to:
brentrobinson
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
