[fdo][FDO216][Modified] Cannot set Data Property constraint to null, through managed...
Brent Robinson
brent.robinson at autodesk.com
Mon Oct 16 10:16:27 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO216
Type:
Defect
Artifact ID:
FDO216 (Cannot set Data Property constraint to null, through managed FDO API)
Modified by:
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO216: merged from 3.2.x
Modified
File: trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgDataPropertyDefinition.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgDataPropertyDefinition.cpp?view=diff&rev=456&p1=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgDataPropertyDefinition.cpp&r1=455&p2=trunk/Fdo/Managed/Src/OSGeo/FDO/Schema/mgDataPropertyDefinition.cpp&r2=456
File: trunk/Fdo/Managed/UnitTest/mgSchemaTest.cs https://fdocore.osgeo.org/source/browse/fdocore/trunk/Fdo/Managed/UnitTest/mgSchemaTest.cs?view=diff&rev=456&p1=trunk/Fdo/Managed/UnitTest/mgSchemaTest.cs&r1=455&p2=trunk/Fdo/Managed/UnitTest/mgSchemaTest.cs&r2=456
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/Rd/AssociationReader.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/Rd/AssociationReader.cpp?view=diff&rev=456&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Rd/AssociationReader.cpp&r1=455&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Rd/AssociationReader.cpp&r2=456
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
