[fdo][FDO216][Modified] Cannot set Data Property constraint to null, through managed...
Brent Robinson
brent.robinson at autodesk.com
Mon Oct 16 10:27:51 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO216
Type:
Defect
Artifact ID:
FDO216 (Cannot set Data Property constraint to null, through managed FDO API)
Modified by:
Brent Robinson
brentrobinson (brent.robinson at autodesk.com)
The following modifications were made to this artifact:
-- Submission Reviewed set to new value:
Yes
-- Defect Resolution set to new value:
Submitted
-- Artifact Status changed:
Old value:
Assigned
New value:
Resolved
-- Resolution Description set to new value:
Changed managed DataPropertyDefinition::set_ValueConstraint to check for null constraint before getting constraint's unmanaged object.
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
