[fdo][FDO217][New] ODBC Provider with an Oracle datastore is slow when loading ...
Badreddine Karoui
badreddine.karoui at autodesk.com
Wed Oct 18 09:18:54 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO217
Type
Defect
Artifact ID
FDO217 (ODBC Provider with an Oracle datastore is slow when loading schema)
Reported by
Badreddine Karoui
badreddinekaroui (badreddine.karoui at autodesk.com)
New artifact details:
- Description set to new value
The ODBC API used to load the meta data by the FDO ODBC provider is very slow. This is particularly true for the Oracle ODBC provider. Also to make matter worst, the ODBC provider loads one table and one column at a time. This change bypass the ODBC API by directly querying the Oracle meta data table as well as perform a bulk load of all the table and column definition as well as the primary keys.
- Defect Severity set to new value
Medium
- Artifact Status set to new value
New
- Component set to new value
- Artifact created
- Priority set to new value
P2
- Subcomponent set to new value
SCHEMA
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
