[fdo][FDO218][New] SDF: A directory is created when opening a connection
Jack Lee
jack.lee at autodesk.com
Wed Oct 18 09:49:49 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO218
Type
Defect
Artifact ID
FDO218 (SDF: A directory is created when opening a connection)
Reported by
Jack Lee
jacklee (jack.lee at autodesk.com)
New artifact details:
- Artifact Status set to new value
New
- Artifact created
- Description set to new value
When a connection is opened, a temporary directory is created under %temp%(eg. %temp%/sdf2).
These directories are not needed and should not be created.
- Summary set to new value
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
