[fdo][FDO240][Modified] GDAL: Data Model Tile Size returned as 1
Frank Warmerdam
warmerdam at pobox.com
Mon Oct 30 11:52:22 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO240
Type:
Defect
Artifact ID:
FDO240 (GDAL: Data Model Tile Size returned as 1)
Modified by:
Frank Warmerdam
warmerdam (warmerdam at pobox.com)
The following modifications were made to this artifact:
-- Steps to Reproduce set to new value:
Greg,
I'm pretty sure the y image size is 5400. But
why do you think the Y tile size needs to be
5400? Is there some requirement on drivers
that the default y tile size be the whole image?
Internally within the driver, I load stuff into my
working buffer one tile at a time and it is
important that tiles not be to awfully large.
If applications want a single tile, they can
override this though there may be memory use
implications for very large images.
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
