[fdo][FDO240][Modified] GDAL: Data Model Tile Size returned as 1
Frank Warmerdam
warmerdam at pobox.com
Mon Oct 30 12:33:51 EST 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO240
Type:
Defect
Artifact ID:
FDO240 (GDAL: Data Model Tile Size returned as 1)
Modified by:
Frank Warmerdam
warmerdam (warmerdam at pobox.com)
The following modifications were made to this artifact:
Added following comment to artifact::
I discussed a bit with Greg, and he indicates this aspect is not
detailed in the FDO specification, but that the ATIL raster provider
always defaults to one tile/image tile size.
I noted that a one scanline tilesize produces the same result from
the binary reader as a whole-image tile so it shouldn't adversely
affect applications.
Greg will look into whether this needs to be a firm requirement for
use of the client applications.
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
