[fdo][FDO164][Modified] Complete the SDF schema edit
Badreddine Karoui badreddine.karoui at autodesk.com
Mon Sep 11 16:32:46 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO164
Type:
Task
Artifact ID:
FDO164 (Complete the SDF schema edit)
Modified by:
Badreddine Karoui
badreddinekaroui (badreddine.karoui at autodesk.com)
The following modifications were made to this artifact:
-- Description set to new value:
Old value:
This work includes the following edit schema operation:
- Add a new property
- Delete an existing property
- Change the description of a class definition
- Change the description of a property
New value:
- Change the description of a schema, class and property.
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
