[fdo][FDO165][New] Remove MySql kludge to convert to 2D (defects 800158, 738710...
Dan Stoica
dan.stoica at autodesk.com
Mon Sep 11 16:47:38 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO165
Type
Defect
Artifact ID
FDO165 (Remove MySql kludge to convert to 2D (defects 800158, 738710))
Reported by
Dan Stoica
danstoica (dan.stoica at autodesk.com)
New artifact details:
- Description set to new value
A temporary hack for the MySql provider was in place in order to make it work with MAP. MAP used to send all geometries as 3D, but the MySql provider can only handle 2D. The kludge is no longer necessary with the current MAP release.
- Defect Severity set to new value
Medium
- Summary set to new value
- Artifact created
- Artifact Status set to new value
New
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
