[fdo][FDO170][Modified] Fix memory leaks in the providers
Dan Stoica
dan.stoica at autodesk.com
Fri Sep 15 18:06:39 EDT 2006
You can view the artifact detail at the following URL:
https://fdo.osgeo.org/servlets/Scarab/id/FDO170
Type:
Defect
Artifact ID:
FDO170 (Fix memory leaks in the providers)
Modified by:
Dan Stoica
danstoica (dan.stoica at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment. Version control commit message.
FDO170
Modified
File: trunk/Utilities/SchemaMgr/Src/Sm/Lp/ClassDefinition.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Lp/ClassDefinition.cpp?view=diff&rev=365&p1=trunk/Utilities/SchemaMgr/Src/Sm/Lp/ClassDefinition.cpp&r1=364&p2=trunk/Utilities/SchemaMgr/Src/Sm/Lp/ClassDefinition.cpp&r2=365
File: trunk/Utilities/SchemaMgr/Src/Sm/Lp/DataPropertyDefinition.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Lp/DataPropertyDefinition.cpp?view=diff&rev=365&p1=trunk/Utilities/SchemaMgr/Src/Sm/Lp/DataPropertyDefinition.cpp&r1=364&p2=trunk/Utilities/SchemaMgr/Src/Sm/Lp/DataPropertyDefinition.cpp&r2=365
File: trunk/Utilities/SchemaMgr/Src/Sm/Lp/FeatureClass.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Lp/FeatureClass.cpp?view=diff&rev=365&p1=trunk/Utilities/SchemaMgr/Src/Sm/Lp/FeatureClass.cpp&r1=364&p2=trunk/Utilities/SchemaMgr/Src/Sm/Lp/FeatureClass.cpp&r2=365
File: trunk/Utilities/SchemaMgr/Src/Sm/Lp/ObjectPropertyDefinition.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Lp/ObjectPropertyDefinition.cpp?view=diff&rev=365&p1=trunk/Utilities/SchemaMgr/Src/Sm/Lp/ObjectPropertyDefinition.cpp&r1=364&p2=trunk/Utilities/SchemaMgr/Src/Sm/Lp/ObjectPropertyDefinition.cpp&r2=365
File: trunk/Utilities/SchemaMgr/Src/Sm/Lp/SchemaElement.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Lp/SchemaElement.cpp?view=diff&rev=365&p1=trunk/Utilities/SchemaMgr/Src/Sm/Lp/SchemaElement.cpp&r1=364&p2=trunk/Utilities/SchemaMgr/Src/Sm/Lp/SchemaElement.cpp&r2=365
File: trunk/Utilities/SchemaMgr/Src/Sm/Lp/SimplePropertyDefinition.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Lp/SimplePropertyDefinition.cpp?view=diff&rev=365&p1=trunk/Utilities/SchemaMgr/Src/Sm/Lp/SimplePropertyDefinition.cpp&r1=364&p2=trunk/Utilities/SchemaMgr/Src/Sm/Lp/SimplePropertyDefinition.cpp&r2=365
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/DbObject.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/DbObject.cpp?view=diff&rev=365&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/DbObject.cpp&r1=364&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/DbObject.cpp&r2=365
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/Field.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/Field.cpp?view=diff&rev=365&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Field.cpp&r1=364&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Field.cpp&r2=365
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/Index.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/Index.cpp?view=diff&rev=365&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Index.cpp&r1=364&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Index.cpp&r2=365
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/PropertyReader.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/PropertyReader.cpp?view=diff&rev=365&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/PropertyReader.cpp&r1=364&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/PropertyReader.cpp&r2=365
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/Rd/PropertyReader.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/Rd/PropertyReader.cpp?view=diff&rev=365&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Rd/PropertyReader.cpp&r1=364&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Rd/PropertyReader.cpp&r2=365
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/Row.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/Row.cpp?view=diff&rev=365&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Row.cpp&r1=364&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Row.cpp&r2=365
This message was automatically generated by Project Tracker.
More information about the Fdo_issues
