[fdo][FDO171][Modified] New FDO Capabilities for ArcSDE/SHP/SDF
Pierre Dalcourt pierre.dalcourt at autodesk.com
Fri Sep 15 18:21:11 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO171
Type:
Enhancement
Artifact ID:
FDO171 (New FDO Capabilities for ArcSDE/SHP/SDF)
Modified by:
Pierre Dalcourt
pierredalcourt (pierre.dalcourt at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
FDO171
Modified
File: trunk/Providers/SDF/Src/Provider/ExInfoDb.cpp https://fdosdf.osgeo.org/source/browse/fdosdf/trunk/Providers/SDF/Src/Provider/ExInfoDb.cpp?view=diff&rev=106&p1=trunk/Providers/SDF/Src/Provider/ExInfoDb.cpp&r1=105&p2=trunk/Providers/SDF/Src/Provider/ExInfoDb.cpp&r2=106
File: trunk/Providers/SDF/Src/Provider/ExInfoDb.h https://fdosdf.osgeo.org/source/browse/fdosdf/trunk/Providers/SDF/Src/Provider/ExInfoDb.h?view=diff&rev=106&p1=trunk/Providers/SDF/Src/Provider/ExInfoDb.h&r1=105&p2=trunk/Providers/SDF/Src/Provider/ExInfoDb.h&r2=106
File: trunk/Providers/SDF/Src/Provider/SdfConnection.cpp https://fdosdf.osgeo.org/source/browse/fdosdf/trunk/Providers/SDF/Src/Provider/SdfConnection.cpp?view=diff&rev=106&p1=trunk/Providers/SDF/Src/Provider/SdfConnection.cpp&r1=105&p2=trunk/Providers/SDF/Src/Provider/SdfConnection.cpp&r2=106
File: trunk/Providers/SDF/Src/Provider/SdfConnection.h https://fdosdf.osgeo.org/source/browse/fdosdf/trunk/Providers/SDF/Src/Provider/SdfConnection.h?view=diff&rev=106&p1=trunk/Providers/SDF/Src/Provider/SdfConnection.h&r1=105&p2=trunk/Providers/SDF/Src/Provider/SdfConnection.h&r2=106
File: trunk/Providers/SDF/Src/Provider/SdfDescribeSchema.cpp https://fdosdf.osgeo.org/source/browse/fdosdf/trunk/Providers/SDF/Src/Provider/SdfDescribeSchema.cpp?view=diff&rev=106&p1=trunk/Providers/SDF/Src/Provider/SdfDescribeSchema.cpp&r1=105&p2=trunk/Providers/SDF/Src/Provider/SdfDescribeSchema.cpp&r2=106
File: trunk/Providers/SDF/Src/UnitTest/ApplySchemaTest.cpp https://fdosdf.osgeo.org/source/browse/fdosdf/trunk/Providers/SDF/Src/UnitTest/ApplySchemaTest.cpp?view=diff&rev=106&p1=trunk/Providers/SDF/Src/UnitTest/ApplySchemaTest.cpp&r1=105&p2=trunk/Providers/SDF/Src/UnitTest/ApplySchemaTest.cpp&r2=106
File: trunk/Providers/SDF/Src/UnitTest/ApplySchemaTest.h https://fdosdf.osgeo.org/source/browse/fdosdf/trunk/Providers/SDF/Src/UnitTest/ApplySchemaTest.h?view=diff&rev=106&p1=trunk/Providers/SDF/Src/UnitTest/ApplySchemaTest.h&r1=105&p2=trunk/Providers/SDF/Src/UnitTest/ApplySchemaTest.h&r2=106
File: trunk/Providers/SDF/Src/UnitTest/apply_schema_test1_master.xml https://fdosdf.osgeo.org/source/browse/fdosdf/trunk/Providers/SDF/Src/UnitTest/apply_schema_test1_master.xml?view=diff&rev=106&p1=trunk/Providers/SDF/Src/UnitTest/apply_schema_test1_master.xml&r1=105&p2=trunk/Providers/SDF/Src/UnitTest/apply_schema_test1_master.xml&r2=106
File: trunk/Providers/SDF/Src/UnitTest/apply_schema_test2_master.xml https://fdosdf.osgeo.org/source/browse/fdosdf/trunk/Providers/SDF/Src/UnitTest/apply_schema_test2_master.xml?view=diff&rev=106&p1=trunk/Providers/SDF/Src/UnitTest/apply_schema_test2_master.xml&r1=105&p2=trunk/Providers/SDF/Src/UnitTest/apply_schema_test2_master.xml&r2=106
File: trunk/Providers/SDF/Src/UnitTest/apply_schema_test3_master.xml https://fdosdf.osgeo.org/source/browse/fdosdf/trunk/Providers/SDF/Src/UnitTest/apply_schema_test3_master.xml?view=diff&rev=106&p1=trunk/Providers/SDF/Src/UnitTest/apply_schema_test3_master.xml&r1=105&p2=trunk/Providers/SDF/Src/UnitTest/apply_schema_test3_master.xml&r2=106
File: trunk/Providers/SDF/Src/UnitTest/apply_schema_test4_master.xml https://fdosdf.osgeo.org/source/browse/fdosdf/trunk/Providers/SDF/Src/UnitTest/apply_schema_test4_master.xml?view=diff&rev=106&p1=trunk/Providers/SDF/Src/UnitTest/apply_schema_test4_master.xml&r1=105&p2=trunk/Providers/SDF/Src/UnitTest/apply_schema_test4_master.xml&r2=106
File: trunk/Providers/SDF/Src/UnitTest/apply_schema_test5_master.xml https://fdosdf.osgeo.org/source/browse/fdosdf/trunk/Providers/SDF/Src/UnitTest/apply_schema_test5_master.xml?view=diff&rev=106&p1=trunk/Providers/SDF/Src/UnitTest/apply_schema_test5_master.xml&r1=105&p2=trunk/Providers/SDF/Src/UnitTest/apply_schema_test5_master.xml&r2=106
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
