[fdo][FDO170][Modified] Fix memory leaks in the providers
Dan Stoica dan.stoica at autodesk.com
Fri Sep 22 16:01:54 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO170
Type:
Defect
Artifact ID:
FDO170 (Fix memory leaks in the providers)
Modified by:
Dan Stoica
danstoica (dan.stoica at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
FDO170
Modified
File: trunk/Providers/SHP/Src/ShpRead/ShapeCPG.cpp https://fdoshp.osgeo.org/source/browse/fdoshp/trunk/Providers/SHP/Src/ShpRead/ShapeCPG.cpp?view=diff&rev=91&p1=trunk/Providers/SHP/Src/ShpRead/ShapeCPG.cpp&r1=90&p2=trunk/Providers/SHP/Src/ShpRead/ShapeCPG.cpp&r2=91
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
