[fdo][FDO170][Modified] Fix memory leaks in the providers
Dan Stoica dan.stoica at autodesk.com
Fri Sep 22 16:03:07 EDT 2006
You can view the artifact detail at the following URL:
    https://fdo.osgeo.org/servlets/Scarab/id/FDO170
Type:
Defect
Artifact ID:
FDO170 (Fix memory leaks in the providers)
Modified by:
Dan Stoica
danstoica (dan.stoica at autodesk.com)
The following modifications were made to this artifact:
Added following comment to artifact::
Automated Comment.  Version control commit message.
FDO170
Modified
File: trunk/Utilities/SchemaMgr/Src/Sm/Lp/ClassDefinition.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Lp/ClassDefinition.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Lp/ClassDefinition.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Lp/ClassDefinition.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Lp/FeatureClass.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Lp/FeatureClass.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Lp/FeatureClass.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Lp/FeatureClass.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Lp/GeometricPropertyDefinition.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Lp/GeometricPropertyDefinition.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Lp/GeometricPropertyDefinition.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Lp/GeometricPropertyDefinition.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Lp/ObjectPropertyDefinition.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Lp/ObjectPropertyDefinition.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Lp/ObjectPropertyDefinition.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Lp/ObjectPropertyDefinition.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Lp/PropertyDefinition.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Lp/PropertyDefinition.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Lp/PropertyDefinition.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Lp/PropertyDefinition.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Lp/SpatialContextCollection.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Lp/SpatialContextCollection.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Lp/SpatialContextCollection.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Lp/SpatialContextCollection.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/AssociationReader.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/AssociationReader.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/AssociationReader.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/AssociationReader.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/ClassReader.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/ClassReader.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/ClassReader.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/ClassReader.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/ClassWriter.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/ClassWriter.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/ClassWriter.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/ClassWriter.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/DependencyReader.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/DependencyReader.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/DependencyReader.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/DependencyReader.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/Field.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/Field.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Field.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Field.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/Fkey.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/Fkey.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Fkey.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Fkey.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/LockTypes.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/LockTypes.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/LockTypes.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/LockTypes.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/Mgr.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/Mgr.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Mgr.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Mgr.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/Mt/ClassTableJoin.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/Mt/ClassTableJoin.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Mt/ClassTableJoin.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Mt/ClassTableJoin.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/Mt/PropertyReader.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/Mt/PropertyReader.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Mt/PropertyReader.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Mt/PropertyReader.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/Mt/SchemaReader.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/Mt/SchemaReader.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Mt/SchemaReader.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Mt/SchemaReader.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/OptionsReader.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/OptionsReader.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/OptionsReader.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/OptionsReader.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/Owner.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/Owner.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Owner.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Owner.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/PropertyReader.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/PropertyReader.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/PropertyReader.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/PropertyReader.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/PropertyWriter.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/PropertyWriter.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/PropertyWriter.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/PropertyWriter.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/Rd/Join.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/Rd/Join.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Rd/Join.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Rd/Join.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/Rd/PropertyReader.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/Rd/PropertyReader.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Rd/PropertyReader.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Rd/PropertyReader.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/Rd/QueryReader.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/Rd/QueryReader.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Rd/QueryReader.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Rd/QueryReader.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/SADReader.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/SADReader.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/SADReader.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/SADReader.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/SADWriter.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/SADWriter.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/SADWriter.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/SADWriter.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/SOReader.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/SOReader.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/SOReader.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/SOReader.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/SOWriter.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/SOWriter.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/SOWriter.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/SOWriter.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/SchemaReader.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/SchemaReader.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/SchemaReader.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/SchemaReader.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/SchemaWriter.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/SchemaWriter.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/SchemaWriter.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/SchemaWriter.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/SpatialContextGeomReader.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/SpatialContextGeomReader.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/SpatialContextGeomReader.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/SpatialContextGeomReader.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/SpatialContextGeomWriter.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/SpatialContextGeomWriter.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/SpatialContextGeomWriter.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/SpatialContextGeomWriter.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/SpatialContextGroupReader.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/SpatialContextGroupReader.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/SpatialContextGroupReader.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/SpatialContextGroupReader.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/SpatialContextGroupWriter.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/SpatialContextGroupWriter.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/SpatialContextGroupWriter.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/SpatialContextGroupWriter.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/SpatialContextReader.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/SpatialContextReader.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/SpatialContextReader.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/SpatialContextReader.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/SpatialContextWriter.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/SpatialContextWriter.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/SpatialContextWriter.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/SpatialContextWriter.cpp&r2=389
File: trunk/Utilities/SchemaMgr/Src/Sm/Ph/Table.cpp https://fdocore.osgeo.org/source/browse/fdocore/trunk/Utilities/SchemaMgr/Src/Sm/Ph/Table.cpp?view=diff&rev=389&p1=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Table.cpp&r1=388&p2=trunk/Utilities/SchemaMgr/Src/Sm/Ph/Table.cpp&r2=389
This message was automatically generated by Project Tracker.
More information about the Fdo_issues mailing list
