[FOSS-GPS] Openmoko Freerunner compatible GPS software
Abdelrazak Younes younes.abdel at gmail.com
Tue Sep 23 06:00:42 EDT 2008
On 23/09/2008 09:35, Fabrizio Giudici wrote:
> Abdelrazak Younes wrote:
>> On 23/09/2008 09:13, Fabrizio Giudici wrote:
>> Hello Fabrizio,
>> I hope I won't sound too pedantic but it would be nice if we impose
>> as a rule that top-posting is forbidden in this list. This helps the
>> reading tremendously. Thanks in advance.
> Fine for me.
Thanks, I hope everybody will agree to obey this rule.
>>> Can you try windRose? Official testing so far is only on PalmOS, but
>>> I know some people has run it over other MIDP phones. If it need
>>> fixes for windRose, I'd made it happily.
>> I also own a Freerunner, I can try next week if I found the time. I
>> also have an NMEA capable Ublox evaluation board connected to my
>> Windows box. I can try to test windRose on this configuration if that
>> interests you.
> Yes, thanks you very much.
double-clicking on windRose.jar on the windows explorer gives me this
message box:
Java Virtual Machine Launcher
Failed to load Main-Class manifest attribute from
C:\devel\windRose\windRose.jar
If I try at the command-line, I get:
C:\devel\windRose>java windRose.jar
Exception in thread "main" java.lang.NoClassDefFoundError: windRose/jar
Caused by: java.lang.ClassNotFoundException: windRose.jar
         at java.net.URLClassLoader$1.run(Unknown Source)
         at java.security.AccessController.doPrivileged(Native Method)
         at java.net.URLClassLoader.findClass(Unknown Source)
         at java.lang.ClassLoader.loadClass(Unknown Source)
         at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
         at java.lang.ClassLoader.loadClassInternal(Unknown Source)
My java installation is as follow:
C:\devel\windRose>java -version
java version "1.6.0_07"
Java(TM) SE Runtime Environment (build 1.6.0_07-b06)
Java HotSpot(TM) Client VM (build 10.0-b23, mixed mode, sharing)
Abdel.
More information about the FOSS-GPS mailing list
