[FOSS-GPS] Introduction TravelingSalesman by Marcus Wolschon
Abdelrazak Younes younes.abdel at gmail.com
Tue Sep 23 07:52:32 EDT 2008
On 23/09/2008 13:39, Marcus Wolschon wrote:
> 2008/9/23 Abdelrazak Younes<younes.abdel at gmail.com>:
>>> Hi again Marcus,
>>> I suppose it is fair to try your application after trying windRose.
>>> So how am I supposed to test this on Windows? I've downloaded all tree jar
>>> file in a directory and I double-clicked
>>> 'traveling_salesman-0.7.1.signed.jar'. A frozen java windows appears
>>> occupying all the CPU, I had to kill it with the task manager (javaw.exe).
> Hello Abdelrazak,
> the current SVN-version is much more stable. I plan to
> release a new version as soon as some rendering-bugs
> are fixed. However I am currently occupied with work
> and an upcomming release of jGnucashLib , so this may
> take quite a while.
Take your time, real-life is important too ;-)
> The error-message you see is due to it trying to fetch
> a pre-rendered map-image from the OpenStreetMap
> tile-server (because it does not yet have a local map).
> However the URLs have changed so it cannot access
> anything there.
> The current SVN-version has a much better error-handling.
I'll try, maybe next week.
Abdel.
More information about the FOSS-GPS mailing list
