[FOSS-GPS] High accuracy positioning with low cost GPS
devices:a FOSS project
ttakasu
ttaka at yk.rim.or.jp
Wed May 6 16:55:48 EDT 2009
Hello Eugenio and Jaykob
>>Do you have any idea about how to handle these time-tag issue?
Time-tag difference between receivers has usually no problem
because the satellite clock is highly stable.
By satellite-side single-difference, receiver clock error,
is perfectly canceled if the receiver inter-channel bias is
zero.
Concerning receiver-side single-difference, the difference
of the signal reception time (strictly, the difference of
transmission time) brings slight error mainly due to satellite
clock drift (and atmospheric effect, orbit error). But in a few
seconds, usually it is negligible in the current SA terminated
condition.
So time-tag adjustment is possible but not necessary for
usual relative positioning process.
T.Takasu
http://gpspp.sakura.ne.jp/indexe.html
View this message in context: http://n2.nabble.com/High-accuracy-positioning-with-low-cost-GPS-devices%3A-a-FOSS-project-tp1312818p2824354.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS
