[FOSS-GPS] More upcoming FoxtrotGPS releases, and...
Joshua Judson Rosen rozzin at geekspace.com
Sun Aug 29 00:10:26 EDT 2010
Brian Wilson <brian at wildsong.biz> writes:
> On Thu, Aug 26, 2010 at 10:52 PM, Joshua Judson Rosen <rozzin at geekspace.com>
> wrote:
> > Is there some `vital signs' XML schema for heartrate-logging that
> > integrate into a GPX file? Should we invent one? Or should we just
> > log the heartrate data into a separate file?
> > Any thoughts?
> GPX supports extensions, and Garmin has already published the schema for the
> extensions they use to record heart and rpm data.
> http://www8.garmin.com/xmlschemas/TrackPointExtensionv1.xsd
Yes, that seems like just the sort of thing for which I was looking--
thank you.
The next questions that comes to mind: what sort of tools are available
to actually do something with this data?
"Don't be afraid to ask (λf.((λx.xx) (λr.f(rr))))."
More information about the FOSS-GPS mailing list
