[FOSS-GPS] Re: Geolocation services for FoxtrotGPS
Joshua Judson Rosen
rozzin at geekspace.com
Tue May 11 09:21:07 EDT 2010
Guilhem Bonnefille <guilhem.bonnefille at gmail.com> writes:
> 2010/5/8 Joshua Judson Rosen <rozzin at geekspace.com>:
> > > Do you evaluated the telepathy framework? It already implement
> > > geolocation of friends over XMPP.
> > > http://telepathy.freedesktop.org/wiki/
> > There hasn't been any discussion about the possibility of using
> > Telepathy yet--I was not aware that it already had support for
> > doing Geolocation over XMPP; that's exactly the sort of thing
> > that I like to hear, though :)
> Did you read the following posts (in chronological order):
> http://blog.pierlux.com/2009/01/22/empathy-where-are-you/en/
> http://blog.pierlux.com/2009/06/15/geolocation-in-empathy-now-real/en/
Yes, I did.
> > Do you have any experience with these facilities?
> Not really. But I will investigate on this direction. Furthermore, I
> don't know yet what are the services proposed by tangoGPS around
> "friends". Currently, my question is: is this service really useful
> compared to the service already proposed by empathy? Should we
> maintain such service in foxtrotGPS or should we remove it and focus
> foxtrotGPS on other direction?
No, I'm pretty certain that we should keep it--for various reasons.
For one, people do use it--if you turn it on, you can see quite a
number of users posting positions and messages; they deserve something
better than the system that's in place right now. Asking if they should
just go use Empathy instead is sort-of like asking if Empathy users
who want to see a map should just go use foxtrotGPS; obviously, there's
a certain overlap in functionality, but the roles are different enough
that it makes sense for both of them to continue--someone using foxtrotGPS
who wants `a GPS that can show where other people are and even send them
a message' isn't going to be satisfied using Empathy, and someone using
Empathy who wants `an IM client that can show where people are' probably
isn't going to be satisfied replaying Empathy with FoxtrotGPS.
The bigger reason is that, as per <http://www.foxtrotgps.org/roadmap.html>,
there will be a lot of GPS-, GIS-, and navigation-related features that
become possible when we have a generalised system for supporting arbitrary
sets of moving targets and communicating information about them between
instances--tracking `friends' is just one possibility. It'll also open up
the possibility of doing things like `live POIs', storm-tracking, notices
of road-closings and emergency-services activity, commercial dispatch,
or even real-time traffic-/congestion-monitoring. Most of that those things
are out in the distance (some of them further than others), but it all
starts here.
"Don't be afraid to ask (λf.((λx.xx) (λr.f(rr))))."
More information about the FOSS-GPS
