[FOSS-GPS] FoxtrotGPS paint-optimize branch
John Stowers
john.stowers.lists at gmail.com
Fri May 14 08:09:27 EDT 2010
> Oh, and two more things:
> The widget seems to use alpha blending quite a lot. This probably won't fly well on the
> freerunner with its limited gfx bandwidth. Is there a way to toggle certain performance
> impacting settings?
There is currently no way to toggle such optimizations. I would want to
see some sort of benchmark to suggest that the alpha component of the
drawing is causing some measurable slowdown before considering this.
> And finally, I think the tile downloading code should be externalized. A widget should not
> introduce a dependency on a http fetcher. Of course you can offer the current downloading
> code as an extra module which you can plug in, but the application should be allowed to
> replace that with its own downloader. So basically that would introduce a
> 'request_tile_url' callback, and a 'tile_ready' function to signal the availability of the
> new tile.
I'm not a fan of this idea sorry. IMO osm-gps-map should be
* "batteries included"
* a good GObject/Gtk+ citizen
I dont think thaqt suggestion is aligned with these goals.
Cheers,
John
More information about the FOSS-GPS
