[FOSS-GPS] FoxtrotGPS paint-optimize branch
Sander van Grieken
sander at 3v8.net
Sat May 15 05:09:17 EDT 2010
On Friday 14 May 2010 14:09:27 John Stowers wrote:
> > Oh, and two more things:
> > The widget seems to use alpha blending quite a lot. This probably won't fly well on
the
> > freerunner with its limited gfx bandwidth. Is there a way to toggle certain
performance
> > impacting settings?
> There is currently no way to toggle such optimizations. I would want to
> see some sort of benchmark to suggest that the alpha component of the
> drawing is causing some measurable slowdown before considering this.
It's only when the HDOP circle gets very big that a big area is alpha-blended, so probably
not interesting right now to look into it. In normal use this will have little impact.
So, never mind :)
> > And finally, I think the tile downloading code should be externalized. A widget should
not
> > introduce a dependency on a http fetcher. Of course you can offer the current
downloading
> > code as an extra module which you can plug in, but the application should be allowed
to
> > replace that with its own downloader. So basically that would introduce a
> > 'request_tile_url' callback, and a 'tile_ready' function to signal the availability of
the
> > new tile.
> I'm not a fan of this idea sorry. IMO osm-gps-map should be
> * "batteries included"
Well it should not be taken out, but the possibility of overriding it sounds interesting,
although for foxtrot I'll take the built-in downloader.
> * a good GObject/Gtk+ citizen
Hmm I don't know exactly what that means, I'm more of a ObjectOriented/C++ kind of guy,
where 'separation of concerns' is one of the important axioms.
Besides, there was talk on this list about a tile provider library, which would rhyme with
this separation.
So my point basically is, you can have batteries included without discarding the concept
of separation of concerns.
grtz,
Sander
More information about the FOSS-GPS
