[FOSS-GPS] patches for osm-gps-map nits (was: FoxtrotGPS Mapping
Library)
Joshua Judson Rosen
rozzin at geekspace.com
Wed May 19 00:00:19 EDT 2010
Joshua Judson Rosen <rozzin at geekspace.com> writes:
> So, it looks like osm-gps-map would mostly be a pretty good fit to
> FoxtrotGPS.
> There are a few things that initially scared me but have turned out to
> be non-issues and a few minor nits for which I'm preparing some patches
> foryour review, but also a couple of other items that are still bothering me
> and for which I don't have a solution on-hand.
... and the nits are, which patches attached at the end...:
* The pkg-config probes for GLib and Cairo appear to demand
unnecessarily-high revisions of both packages; the versions in
Debian's current stable release seem to work fine (the `mapviewer'
demo app seems to build and work fine on my laptop).
* The way that the pkg-config probes are combined & labelled makes
the output from ./configure confusing (as well as the error
when the list of prerequisites is unsatisfied, which made me go
`What do you mean it failed when looking for OPENSTREETMAP_GPS_MAP!?
Isn't that what I'm building? Oh...').
* `./configure && make install' doesn't work in a dedicated build-tree
(outside of the source-tree).
* The using a funky trick with the linker where you `backdoor'
in past libtool, which I *think* is unnecessary and may lead
to problems (or at least confusion) for someone some day.
"Don't be afraid to ask (λf.((λx.xx) (λr.f(rr))))."
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/foss-gps/attachments/20100519/0358e1c6/0002-It-looks-like-GLib-2.16-and-Cairo-1.6-are-actually-s.bin
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/foss-gps/attachments/20100519/0358e1c6/0003-Simplified-build-relationship-between-mapviewer-and.bin
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/foss-gps/attachments/20100519/0358e1c6/0004-Don-t-backdoor-in-through-.libs-just-let-libtool-do.bin
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/foss-gps/attachments/20100519/0358e1c6/0005-Support-building-outside-the-source-tree.bin
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/foss-gps/attachments/20100519/0358e1c6/0006-Split-pkg-config-probes-for-less-confusing-.-configu.bin
More information about the FOSS-GPS
