[FOSS-GPS] patches for osm-gps-map nits (was: FoxtrotGPS Mapping
Library)
John Stowers
john.stowers.lists at gmail.com
Wed May 19 01:12:01 EDT 2010
On Wed, May 19, 2010 at 4:00 PM, Joshua Judson Rosen
<rozzin at geekspace.com>wrote:
> Joshua Judson Rosen <rozzin at geekspace.com> writes:
> > So, it looks like osm-gps-map would mostly be a pretty good fit to
> > FoxtrotGPS.
> > There are a few things that initially scared me but have turned out to
> > be non-issues and a few minor nits for which I'm preparing some patches
> > foryour review, but also a couple of other items that are still bothering
> me
> > and for which I don't have a solution on-hand.
> ... and the nits are, which patches attached at the end...:
> * The pkg-config probes for GLib and Cairo appear to demand
> unnecessarily-high revisions of both packages; the versions in
> Debian's current stable release seem to work fine (the `mapviewer'
> demo app seems to build and work fine on my laptop).
> * The way that the pkg-config probes are combined & labelled makes
> the output from ./configure confusing (as well as the error
> when the list of prerequisites is unsatisfied, which made me go
> `What do you mean it failed when looking for OPENSTREETMAP_GPS_MAP!?
> Isn't that what I'm building? Oh...').
> * `./configure && make install' doesn't work in a dedicated build-tree
> (outside of the source-tree).
> * The using a funky trick with the linker where you `backdoor'
> in past libtool, which I *think* is unnecessary and may lead
> to problems (or at least confusion) for someone some day.
Excellent, I am away from my development computer for a few days, but I will
apply them when I get back.
Thanks for your work,
John
> "Don't be afraid to ask (λf.((λx.xx) (λr.f(rr))))."
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: http://lists.osgeo.org/pipermail/foss-gps/attachments/20100519/7a903f9a/attachment-0001.html
More information about the FOSS-GPS
