[FOSS-GPS] FoxtrotGPS Mapping Library
John Stowers john.stowers.lists at gmail.com
Mon May 24 07:50:54 EDT 2010
> > You should be able to connect to "changed" which is called anytime the
> > bounding box is changed, i.e. zoom or scroll. I should probably also
> > emit notify::zoom signal here (i.e. patch welcome)
> "changed" will do, thanks :)
notify::zoom has been implemented in git HEAD
John
More information about the FOSS-GPS mailing list
