[FOSS-GPS] FoxtrotGPS Mapping Library
John Stowers
john.stowers.lists at gmail.com
Tue May 25 00:41:04 EDT 2010
>> The current implementation osm_gps_map_get_scale takes the scale at
>> the center. Do you want me to expose
>> osm_gps_map_get_scale_at_point (which is currently private)?
> No, the center is fine, but if that take_scale function is working correctly, then it's
> probably another bug. My observation is that the OSD scale indicator doesn't get updated
> when staying in the same zoom level but dragging the map to another latitude.
This has been fixed in git HEAD
John
More information about the FOSS-GPS
