[FOSS-GPS] introduction and first help request
Mauro Ugarte A
mauro.ugarte at cefop.udec.cl
Wed May 26 18:13:31 EDT 2010
Hi to everyone,
I'm Mauro Ugarte, electronic engineering student at Universidad de
Concepción, Chile (spanish native speaker, so excuse my english). I'm
working on my undergraduate thesis taking part of a new small research
team whose objective is to develop a low cost system for real time
relative precise positioning (at least 0.6 m relative to some fixed
point, geodesic precission is always desirable but in our case not
crucial or extremely needed) of pedestrian rovers (5-15 kph), on a small
baseline (0 - 5 km), so discovering this mailing list almost makes me
cry ;'-).
As a start, we are going to follow some of the paths signaled here
(rtklib, gogps), but we lack of two fundamental parts:
1- First of all, in Chile there is nothing like a GPS reference station
network providing corrections on NRTK/NTRIP, which we could rely on.
There is an IGS station, though. It is near our lab (about 3 km),
codenamed CONZ and labeled "highrate_permanent" under GNSS/files > Data
Archive > File Browser at GNSS Data Center website
(http://igs.bkg.bund.de/index/index) and provides RINEX files that
should help at post-processing but not for real time aplications (please
correct me if i'm wrong).
2- Even when the excellent works aforementioned (rtklib, gogps) clearly
stated which GPS module was used to conduct the research (primarily the
u-blox LEA-4T), we noted that u-blox is getting that module out of the
market (the entire xxx-4x line) so doing some futuristic thinking, we
don't want to do all the research to rely on hardware with extinction
deadline.
So, considering the above, let me ask this:
1- Should we buy a RTK capable reference station module, that outputs
RTCM-RTK messages to use them as an input to rtklib/gogps? (example:
magellan DG-14), or could we use another low cost module that outputs
raw data measurements and "convert" that raw data into the corresponding
RTCM-RTK messages to feed rtklib/gogps?. I ask this because it seems to
me that RTCM V3.1 messages broadcasted by RTK reference stations
(1001-1002 for precision GPS L1 only, 1003-1004 for precision GPS L1 &
L2) could be "constructed" by raw data output, and messages 1005-1006
too, using the station position. Is all this possible or am i missing
something?
2- Do you know alternatives to LEA-4T, at low cost, that seems to you
that should stay around at least a couple of years and output raw data
which we can feed (or convert to feed) to rtklib/gogps?. We know that
there are the u-blox LEA-5T and LEA-6T, but those output raw data at 2
Hz and 5 Hz respectively, and the last one is just born so firmware bugs
could happen as they happened to LEA-5T, so if you know another faster
and cheaper, please let me know.
Finally, my gratitude for all the hard work done here.
Sincerely yours,
Mauro Ugarte A.
Este correo electrónico y cualquier archivo adjunto son confidenciales
y son solamente para el uso del individuo o entidad a la que van dirigidos.
Si ha recibido este correo electrónico por error por favor notifique al
remitente. Este mensaje contiene información confidencial dirigida a la
persona implicada. Si usted no es esa persona no debiera diseminar,
distribuir o copiar este mensaje de correo electrónico.
More information about the FOSS-GPS
