Sander van Grieken <sander at 3v8.net> writes: > requirement, which makes it probably a less than smooth experience because AFAIK it is > incompatible with fso-gpsd. If the libgps of your distro is configured to talk the old protocol by default then it should work with fso-gpsd.
