[FOSS-GPS] FoxtrotGPS support for fso-gpsd (was: First impressions
of FoxtrotGPS on the Freerunner)
Joshua Judson Rosen
rozzin at geekspace.com
Fri May 28 00:10:57 EDT 2010
Timo Juhani Lindfors <timo.lindfors at iki.fi> writes:
> Sander van Grieken <sander at 3v8.net> writes:
> > requirement, which makes it probably a less than smooth experience
> > because AFAIK it is incompatible with fso-gpsd.
> If the libgps of your distro is configured to talk the old protocol by
> default then it should work with fso-gpsd.
Actually, even if it's configured to talk the new protocol by default,
I believe it should (surprisingly enough) still work with fso-gpsd.
"Don't be afraid to ask (λf.((λx.xx) (λr.f(rr))))."
More information about the FOSS-GPS
