[FOSS-GPS] rtklib: Initial setup
Degerman Pär par.degerman at scania.com
Mon Nov 29 06:26:49 EST 2010
Sure, I have recorded a one hour log using RTKNAVI. It can be downloaded from here:
http://wikisend.com/download/506262/ubx.log
It will be kept at that location for seven days.
Regards
Pär
-----Original Message-----
From: foss-gps-bounces at lists.osgeo.org [mailto:foss-gps-bounces at lists.osgeo.org] On Behalf Of Timo Juhani Lindfors
Sent: den 29 november 2010 11:07
To: Open Source GPS-related discussion and support
Subject: Re: [FOSS-GPS] rtklib: Initial setup
Degerman Pär <par.degerman at scania.com> writes:
> When I press start I get alternating Green and Dark Green light on a
> single light in the input section and a constant dark green light in
> the middle section. But no position whatsoever. Does anyone have a
> clue on what I should change to get this setup working?
I don't have Windows but I can work with the command line tools. Can
you save traffic that the GPS is sending through serial port for
e.g. 15 minutes and put that online somewhere so that we can take a
look?
This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS mailing list
