[FOSS-GPS] Questions about foxtrotgps
James Hiebert
james at hiebert.name
Mon Oct 11 20:33:16 EDT 2010
FOSS-GPS:
I have been using tangogps on my Neo Freerunner (running debian) for a about
a year and have been very pleased with it. A couple weeks ago, after a
package upgrade tangogps simply stopped working. I haven't quite figured
out why, but I suspect it had something to do with the change in protocol
for gpsd that occurred at about the same time. _Supposedly_ I'm supposed to
use a wedge package, fso-gpsd which interfaces with the Freerunner's dbus
interface to the gps chip and acts like gpsd. However, attepting to install
fso-gpsd removes both tangogps and foxtrot gps. Which brings me to my
questions:
1) Does foxtrotgps directly support the dbus interface to the gps? I
presume that the answer is 'no', but would be willing to work on programming
such a feature with a little guidance from someone who knows more about this
than me. Or is there some other way to get foxtrotgps to listen to the gps
chip?
2) This is unrelated. I think that the "map detail" option in the map
context menu is broken. I clicked the "map detail->fewer/larger details"
option at one point. However now the map is stuck there. If I click the
"map detail->more smaller details" option I get no change. Is there some
place that exposes this option elsewhere (maybe through gconf, on which I'm
no expert)?
Thanks in advance for any help.
~James Hiebert
More information about the FOSS-GPS
