[FOSS-GPS] Questions about foxtrotgps
James Hiebert
james at hiebert.name
Tue Oct 12 10:40:46 EDT 2010
> Hmm, tangogps is not in debian anymore.
Well, it still shows up in my apt. Is this an error?
# apt-cache showpkg tangogps
Package: tangogps
Versions:
0.99.4+debian3-1
(/var/lib/apt/lists/ftp2.de.debian.org_debian_dists_sid_main_binary-armel_Packages)
(/var/lib/dpkg/status)
Description Language:
File:
MD5: 9171a6378bda90539ab34439b2a117d0
Reverse Depends:
foxtrotgps,tangogps
foxtrotgps,tangogps 0.99.4+debian2
Dependencies:
0.99.4+debian3-1 - foxtrotgps (0 (null))
Provides:
0.99.4+debian3-1 -
Reverse Provides:
> strace -o foxtrotgps.strace -s4096 -f foxtrotgps
OK, it is attached.
FWIW, none of the gpsd suite of applications (gpscat, xgps, gpsmon) get any
info from the gps. However if I run zhone (the phone application on my Neo
Freerunner), it is able to see a wide range of satellites and get a 3-d fix.
Presumably, this is because it correctly uses the dbus interface. Does
foxtrotgps not support the dbus/gypsy interface to the gps?
~James
On Tue, Oct 12, 2010 at 07:24:26AM +0300, Timo Juhani Lindfors wrote:
> James Hiebert <james at hiebert.name> writes:
> > package upgrade tangogps simply stopped working.
> Hmm, tangogps is not in debian anymore. Foxtrotgps should afaik talk
> both the old and new gpsd protocol. Please run
> and hit ctrl-c when the interface has started but gps is still not
> working. Then use e.g. "bzip2 -9 foxtrotgps.strace" to compress the
> log and send the resulting foxtrotgps.strace.bz2 here or to a bug
> report if it is larger than a few kilobytes.
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/foss-gps/attachments/20101012/718abbfe/foxtrotgps.strace-0001.obj
More information about the FOSS-GPS
