[FOSS-GPS] Tango/Foxtrot GPS - Plotting locations of multiple
things
Jay Ashworth
jra at baylink.com
Wed Apr 27 10:29:28 EDT 2011
---- Original Message -----
> From: "Ben McCarthy" <b.mccarthy at lancaster.ac.uk>
> I don't have my code uploaded anywhere at the min, but it is
> essentially
> just the TangoGPS code (certainly with regards to the graphical
> elements).
> All I have done is adapt the "Friends" part to accept lat/lons from a
> socket
> rather than from the "Friends" server.
This is an item that I was interested in myself when Tango came out,
I *believe* that Rozzin actually has it on the roadmap, though I've fallen
off the edge of the earth somewhat -- being unemployed leaves you a lot
less spare time and energy than you'd expect... and taking a crappy
replacement job even less so.
My inclination is to say that the best end-game would in fact be for us
to find you some help getting the mods to Fox that you've created to behave
the way you'd like -- especially if your code is well-factored and modular
enough to be adaptable to other similar uses -- that way both you and the
project can mark a win in the column.
I may or may not be that guy, but I can certainly tug on Joshua's sleeve
if he hasn't noticed this thread already. He knows the code quite well,
as do several other contributors.
Cheers,
- jra
More information about the FOSS-GPS
