[FOSS-GPS] Can't get Ambiguity Validation Ratio to move
Tomoji Takasu
ttaka at yk.rim.or.jp
Mon Jun 20 04:56:03 EDT 2011
Dear Danny
> In the data window of RTKNavi, I noticed the Lat/long/height of Base is
> not listed with real numbers (90deg 0m). This isn't right- that GPS has a
> fine solution in NMEA.
You have to set the base-station position properly in
Options dialog for relative modes. RTKNAVI never uses
receiver's NMEA.
This is FAQ. So I will add FAQ in the support page.
regards,
Tomoji TAKASU
Sent: Monday, June 20, 2011 5:07 PM
To: <foss-gps at lists.osgeo.org>
Subject: [FOSS-GPS] Can't get Ambiguity Validation Ratio to move
> I'm new to RTK. I have a pair of LEA-6T GPS units, one active Sarantel
> SL-1206 quadrafiliar helix ant. There were supposed to be two of those
> but the second one was DOA so I'm making do with an active patch antenna
> for the second. I don't have an antenna file for either of them. I'm
> using 2.4.1.
> I have UBX RXM-RAW and RXM-SFRB reading out of both of them at 5Hz (tried
> this at 1Hz too). I can get a fix out of either one of them. In
> Kinematic mode of RTKNavi, I get a position, but the "ratio factor of
> ambiguity validation" factor is stuck at 0.0. I waited like an hour and
> it was still at 0.
> fine solution in NMEA. Both Base and Rover are showing strong (~45dbHz)
> signal bars in all colors.
> I looked under Solution 1 and Solution 2 and both have valid, similar
> solutions.
> I looked under errors and saw:
> eight "outlier rejected" per sample period (5Hz)
> one "no double-differenced residuals" message
> I tried switching the COM ports for Base and Rover, effectively switching
> which unit was which (neither is moving right now). Nothing changed, the
> "Base" unit channel still has no Lat/long/height and ambiguity validation
> is still 0. That is, the problem is not tied to the GPS hardware unit.
> I tried disabling the Rover in RTKnavi. There's still no solution under
> the Lat/Long/Height of Base. The signal strength bars all turn gray.
> I tried the mkl version (I have an i7). It didn't change anything.
> I tried 2.4.0 rtknavi. In that one, I can't get a rover solution to show
> up at all, it's blank on the main window and rtkplot shows nothing.
> Any ideas?
> Danny
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS
