[FOSS-GPS] Can't get Ambiguity Validation Ratio to move
Tomoji Takasu ttaka at yk.rim.or.jp
Mon Jun 20 15:40:31 EDT 2011
Dear Danny
> What is the best way to determine a location?  If I use a single unit's
> NMEA, I will not know the location with centimeter accuracy.
Collect receiver data in some period, process them in
"Single" mode and average the results.
> Am I correct in understanding that the small error in base location will
> not affect the relative accuracy of the base-to-rover difference?  Only
> that the absolute location of the rover will be off by an identical
> amount?
You are right.
> It might be useful to have a mode where the output is purely a relative
> distance vector might be useful.  Would that get rid of the need to fix
> exact coordinates for a base?
Use "Moving-Base" mode and output "E/N/U-Baseline".
regards,
Tomoji TAKASU
Sent: Tuesday, June 21, 2011 1:34 AM
To: "Open Source GPS-related discussion and support"
<foss-gps at lists.osgeo.org>
Subject: Re: [FOSS-GPS] Can't get Ambiguity Validation Ratio to move
> OK- thank you so much!  I will try it out!
> amount?
> I was gonna say "maybe it should get an inaccurate base location from
> NMEA", but SkyTrak-Raw doesn't offer a calculated position fix at all.
> Danny
> On 6/20/2011 3:56 AM, Tomoji Takasu wrote:
>> Dear Danny
>>> In the data window of RTKNavi, I noticed the Lat/long/height of Base is
>>> not listed with real numbers (90deg 0m).  This isn't right- that GPS has
>>> a fine solution in NMEA.
>> You have to set the base-station position properly in
>> Options dialog for relative modes. RTKNAVI never uses
>> receiver's NMEA.
>> This is FAQ. So I will add FAQ in the support page.
>> regards,
>> Tomoji TAKASU
>> From: "Danny Miller" <dannym at austin.rr.com>
>> Sent: Monday, June 20, 2011 5:07 PM
>> To: <foss-gps at lists.osgeo.org>
>> Subject: [FOSS-GPS] Can't get Ambiguity Validation Ratio to move
>>> I'm new to RTK.  I have a pair of LEA-6T GPS units, one active Sarantel
>>> SL-1206 quadrafiliar helix ant.  There were supposed to be two of those
>>> but the second one was DOA so I'm making do with an active patch antenna
>>> for the second.  I don't have an antenna file for either of them.  I'm
>>> using 2.4.1.
>>> I have UBX RXM-RAW and RXM-SFRB reading out of both of them at 5Hz
>>> (tried this at 1Hz too).  I can get a fix out of either one of them.  In
>>> Kinematic mode of RTKNavi, I get a position, but the "ratio factor of
>>> ambiguity validation" factor is stuck at 0.0.  I waited like an hour and
>>> it was still at 0.
>>> a fine solution in NMEA.  Both Base and Rover are showing strong
>>> (~45dbHz) signal bars in all colors.
>>> I looked under Solution 1 and Solution 2 and both have valid, similar
>>> solutions.
>>> I looked under errors and saw:
>>> eight "outlier rejected" per sample period (5Hz)
>>> one "no double-differenced residuals" message
>>> I tried switching the COM ports for Base and Rover, effectively
>>> switching which unit was which (neither is moving right now).  Nothing
>>> changed, the "Base" unit channel still has no Lat/long/height and
>>> ambiguity validation is still 0.  That is, the problem is not tied to
>>> the GPS hardware unit.
>>> I tried disabling the Rover in RTKnavi.  There's still no solution under
>>> the Lat/Long/Height of Base.  The signal strength bars all turn gray.
>>> I tried the mkl version (I have an i7).  It didn't change anything.
>>> I tried 2.4.0 rtknavi.  In that one, I can't get a rover solution to
>>> show up at all, it's blank on the main window and rtkplot shows nothing.
>>> Any ideas?
>>> Danny
>>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
>>> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
>>> subscription
>>> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
>> subscription
> subscription
More information about the FOSS-GPS mailing list
