[FOSS-GPS] Position modes in RTKPOST
Tomoji TAKASU
ttaka at yk.rim.or.jp
Mon Oct 31 19:01:11 EDT 2011
Dear Antonio
I don't know "least mean square". I may be
"least square".
> I think that a) and b) are not suitable to RTK positioning because of the
> ill-conditioning of the design matrix (very short observation time spans,
> frequently one solution per epoch). I'm I right?
Not right.
KF can handle only one epoch observations
(but usually has no meaning). LS or KF is just
a design selection.
> 1. RTKPOST "static" is like c.1)?
> 2. RTKPOST "kinematic" is like c.2) or c.3)?
> 3. And RTKPOST "single"? Is it LMS/WLMS?
In "single", RTKPOST uses weighted LS.
In other modes, RTKPOST uses EKF.
regards,
Tomoji TAKASU
From: "António Pestana" <afsm.pestana at gmail.com>
Sent: Tuesday, November 01, 2011 6:48 AM
To: "Open Source GPS-related discussion and support"
<foss-gps at lists.osgeo.org>
Subject: Re: [FOSS-GPS] Position modes in RTKPOST
> Dear Mr. Takasu an other list members:
> I am aware (not really aware, I've just heard off...) of the following
> solutions to the positioning problem we are dealing with (GNSS
> positioning):
> a) Least mean square (LMS)
> b) Weighted least mean square (WLMS)
> c) Kalman filter
> c.1) static positioning: coordinates of the receiver are constants and the
> estimated clock offset of the receiver is white noise with zero mean
> c.2) kinematic positioning for high receiver velocity: coordinates and
> clock offset are modelled as zero mean white noise
> c.3) kinematic positioning for low velocity: the coordinates are modelled
> as a random walk
> If I'm right then it follows that in RTK we are using some sort of "Kalman
> filter" type solutions. And if we are using "Kalman filters" type
> solutions
> then the following questions arise:
> Regards
> Antonio
> 2011/10/28 Tomoji TAKASU <ttaka at yk.rim.or.jp>
>> Dear Antonio
>> Can anyone explain give me a brief explanation regarding the differences
>>> between the position modes options in RTKPOST? I am especially
>>> interested
>>> in
>>> the following modes: Single, Kinematic, Static, Moving-base and Fixed.
>> I think they are generally common terminologies
>> among GNSS positioning area except for "Fixed".
>> So see the manual and search by Google.
>> "Fixed" is special in RTKLIB. In the mode, the user
>> position is fixed to a priori values specified by user
>> options and other parameters like ionosphere,
>> troposphere are estimated. It is also used for the
>> analysis of measurement noise and multi-path with
>> residuals.
>> regards,
>> Tomoji TAKASU
>> Sent: Saturday, October 29, 2011 3:34 AM
>> To: "Open Source GPS-related discussion and support" <
>> Subject: [FOSS-GPS] Position modes in RTKPOST
>>> interested
>>> in
>>> Regards
>>> Antonio
>> ______________________________**_________________
>>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
>>> Visit
>>> http://lists.osgeo.org/**mailman/listinfo/foss-gps<http://lists.osgeo.org/mailman/listinfo/foss-gps>to
>>> manage your subscription
>>> For more information, check
>>> http://wiki.osgeo.org/wiki/**FOSS-GPS<http://wiki.osgeo.org/wiki/FOSS-GPS>
>> Visit
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS
