[FOSS-GPS] Kinematic vs PPP Kinematic?
Danny Miller
dannym at austin.rr.com
Tue Aug 28 04:17:07 PDT 2012
My mistake- NEO 6P.
Ah Michele, I didn't realize you were on the list, I've been following
your blog periodically. I guess I didn't realize I was seeing your name
in two different places... how odd, I've been reading your answers to my
questions!
Danny
On 8/28/2012 5:24 AM, Michele Bavaro wrote:
> I am not aware of any uBlox LEA-6P?
> I have and use regularly NEO-6P though, which has PPP and carrier
> phase output.
> The only drawback of NEO6P is that it uses a simple crystal instead of
> a TCXO so the Doppler values will be generally quite high.
> That does not impact the carrier phase output quality however: in zero
> baseline mode -in very good visibility conditions- "static" gives me
> just a few mm variance and zero mean.
> As I mentioned ealier in PPP mode it does not make sense to talk about
> rover and base as it is a _standalone_ positioning mode.
> The hacked version of RTKLIB for NV08C is actually here:
> http://www.onetalent-gnss.com/ideas/usb-hw-receivers/denga10
> and it's currently being updated according to the recently released
> document here:
> http://www.nvs-gnss.com/support/documentation/item/32-binr-protocol-specification.html
> for LLI and SBAS support.
> Cheers,
> Michele
> On 28/08/2012 11:49, Danny Miller wrote:
>> Well, now, I've seen the LEA-6P units are standalone PPP. But RTKLib
>> has kinematic mode which seems to use 2 units and this "differential".
>> I did download the patched version of rtknavi that has a PPP fix.
>> I discovered that the PPP "Static" for determining the base station
>> location was pretty stable- however, it determines the location for
>> the "rover" only, so I just swapped the rover and base port #'s to
>> determine the static base location.
>> When I selected PPP Kinematic, the fix jumps several meters back and
>> forth rapidly, but never seemed to stabilize much, and the noise
>> wasn't really centered on the true location either.
>> I ordered the NV08C-CSM units, BTW. These new kids on the block are
>> GPS AND GLONASS, Galileo, Compass, and SBAS, 2.5m standard accuracy,
>> and a few months back the mfg released firmware to expose the RAW
>> pseudorange data. Michele Bavaro thinks highly of them, and there's
>> a hacked version of RTKLib for them:
>> http://michelebavaro.blogspot.com/
>> So, this should be fun!
>> Danny
>> On 8/28/2012 3:49 AM, Michele Bavaro wrote:
>>> There is a huge difference actually.
>>> The first is differential, the second standalone.
>>> Cheers,
>>> Michele
>>> On 28/08/2012 09:39, Danny Miller wrote:
>>>> Could someone explain the difference between simple Kinematic and
>>>> PPP Kinematic in RTKLib?
>>>> Danny
>>>> _______________________________________________
>>>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing
>>>> list.
>>>> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage
>>>> your subscription
>>>> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
>>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
>>> your subscription
>> This message is sent to you fromFOSS-GPS at lists.osgeo.org mailing list.
>> Visithttp://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
>> For more information, checkhttp://wiki.osgeo.org/wiki/FOSS-GPS
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20120828/d8cdf672/attachment.html>
More information about the FOSS-GPS
