[FOSS-GPS] Kinematic vs PPP Kinematic?
Michele Bavaro
mic.bavaro at yahoo.co.uk
Tue Aug 28 03:24:19 PDT 2012
I am not aware of any uBlox LEA-6P?
I have and use regularly NEO-6P though, which has PPP and carrier phase
output.
The only drawback of NEO6P is that it uses a simple crystal instead of a
TCXO so the Doppler values will be generally quite high.
That does not impact the carrier phase output quality however: in zero
baseline mode -in very good visibility conditions- "static" gives me
just a few mm variance and zero mean.
As I mentioned ealier in PPP mode it does not make sense to talk about
rover and base as it is a _standalone_ positioning mode.
The hacked version of RTKLIB for NV08C is actually here:
http://www.onetalent-gnss.com/ideas/usb-hw-receivers/denga10
and it's currently being updated according to the recently released
document here:
http://www.nvs-gnss.com/support/documentation/item/32-binr-protocol-specification.html
for LLI and SBAS support.
Cheers,
Michele
On 28/08/2012 11:49, Danny Miller wrote:
> Well, now, I've seen the LEA-6P units are standalone PPP. But RTKLib
> has kinematic mode which seems to use 2 units and this "differential".
> I did download the patched version of rtknavi that has a PPP fix.
> I discovered that the PPP "Static" for determining the base station
> location was pretty stable- however, it determines the location for
> the "rover" only, so I just swapped the rover and base port #'s to
> determine the static base location.
> When I selected PPP Kinematic, the fix jumps several meters back and
> forth rapidly, but never seemed to stabilize much, and the noise
> wasn't really centered on the true location either.
> I ordered the NV08C-CSM units, BTW. These new kids on the block are
> GPS AND GLONASS, Galileo, Compass, and SBAS, 2.5m standard accuracy,
> and a few months back the mfg released firmware to expose the RAW
> pseudorange data. Michele Bavaro thinks highly of them, and there's a
> hacked version of RTKLib for them:
> http://michelebavaro.blogspot.com/
> So, this should be fun!
> Danny
> On 8/28/2012 3:49 AM, Michele Bavaro wrote:
>> There is a huge difference actually.
>> The first is differential, the second standalone.
>> Cheers,
>> Michele
>> On 28/08/2012 09:39, Danny Miller wrote:
>>> Could someone explain the difference between simple Kinematic and
>>> PPP Kinematic in RTKLib?
>>> Danny
>>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
>>> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage
>>> your subscription
>>> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
>> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
>> subscription
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20120828/0853f586/attachment-0001.html>
More information about the FOSS-GPS
