[FOSS-GPS] [Q] ublox EVK-6T setting for RTKlib (video capture
included)
adioshun
adioshun at gmail.com
Tue Jan 3 07:07:14 EST 2012
Dear.
I use a ublox EVK-6T for RTKlib test.
However, the RTKNAVI main screen shows nothing and no log & out files.
Here is a screen capture file (214M) :
https://files.ucloud.com/pf/D49294_6848656_818566 (Valid Until 2012-12-31)
This is what I did.
[00:00~00:37] I set the Output of EVK-6T from NMEA to UBX->the console
stops/maybe it receives nothing : (
[00:38~00:54] Anyway, I run a RTKNAVI and set the option as "Single"
positioning mode
[00:55~01:09] Input is serial and Format is u-blox
[01:10~01:07] Output is file with NMEA format
[01:08~01:25] Log is also file
[01:06~01:26] Press the Start button the upper boxes turn into green and
only the last green box blink
[01:27~02:03] The output and log files are empty
[02:04~02:29] Press the RTK Monitor button
[02:30~02:35] Change the main display option but nothing displayed.
[02:36~02:45] For the last step, I stop the RTKNAVI and open the output file
-> nothing recorded.
What's the problem?
if u know any thing, plz comment me.
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Q-ublox-EVK-6T-setting-for-RTKlib-video-capture-included-tp7146506p7146506.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS
