[FOSS-GPS] [Q] ublox EVK-6T setting for RTKlib (video capture
included)
Mauro Ugarte Avilés
mauro.ugarte at cefop.udec.cl
Tue Jan 3 08:17:49 EST 2012
Hi Adioshun, you need to activate the periodic output of messages
RXM-RAW and RXM-SFRB. On u-center, go to View-->Configuration View (or
press Ctrl+F9). Then on that window, you should see many options on the
left menu, select MSG (Messages) and search for RXM-RAW and RXM-SFRB and
activate them on the interfaces you would be using to feed RTKnavi (you
could use USART0 for these messages and leave USB for control and
configuration inputs and NMEA output, for instance). Only THEN, when
messages are activated and configuration saved (pressing "Send" at the
bottom left of the Configuration view), you should change the output
protocol of the selected port for the RXM messages, to UBX.
Best regards,
Mauro U.
On 03/01/12 09:07, adioshun wrote:
> Dear.
> I use a ublox EVK-6T for RTKlib test.
> However, the RTKNAVI main screen shows nothing and no log& out files.
> Here is a screen capture file (214M) :
> https://files.ucloud.com/pf/D49294_6848656_818566 (Valid Until 2012-12-31)
> This is what I did.
> [00:00~00:37] I set the Output of EVK-6T from NMEA to UBX->the console
> stops/maybe it receives nothing : (
> [00:38~00:54] Anyway, I run a RTKNAVI and set the option as "Single"
> positioning mode
> [00:55~01:09] Input is serial and Format is u-blox
> [01:10~01:07] Output is file with NMEA format
> [01:08~01:25] Log is also file
> [01:06~01:26] Press the Start button the upper boxes turn into green and
> only the last green box blink
> [01:27~02:03] The output and log files are empty
> [02:04~02:29] Press the RTK Monitor button
> [02:30~02:35] Change the main display option but nothing displayed.
> [02:36~02:45] For the last step, I stop the RTKNAVI and open the output file
> -> nothing recorded.
> What's the problem?
> if u know any thing, plz comment me.
> View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Q-ublox-EVK-6T-setting-for-RTKlib-video-capture-included-tp7146506p7146506.html
> Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
Este correo electrónico y cualquier archivo adjunto son confidenciales
y son solamente para el uso del individuo o entidad a la que van dirigidos.
Si ha recibido este correo electrónico por error por favor notifique al
remitente. Este mensaje contiene información confidencial dirigida a la
persona implicada. Si usted no es esa persona no debiera diseminar,
distribuir o copiar este mensaje de correo electrónico.
More information about the FOSS-GPS
