[FOSS-GPS] Re: [Q] ublox EVK-6T setting for RTKlib (video capture
	included)
    Mauro Ugarte Avilés
    mauro.ugarte at cefop.udec.cl
    Tue Jan  3 15:29:37 EST 2012
> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/file/n7147051/main.jpg
> Download(60M) : https://files.ucloud.com/pf/D49294_6848656_818585
> The upper left green box is blinking (input rover)
> However, the left main screen(Lat/Lon/Height) shows nothing
> also the output file full with empty result as follow.
> $GPGSA,A,1,,,,,,,,,,,,,,,*1E
> $GPGSV,1,1,0,,,,,,,,,,,,,,,,*49
It seems from your video and the output file that something is wrong
with the antenna, the satellite's signals should be stronger than that
(the output file shows no satellites at all).
The video shows that observations and navigation (satellite's ephemeris
data) are being collected OK, so fixing the antenna issue should be the
next step.
Mauro U.
> View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Q-ublox-EVK-6T-setting-for-RTKlib-video-capture-included-tp7146506p7147051.html
> Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
   Este correo electrónico y  cualquier archivo adjunto son confidenciales
y son solamente para el uso del individuo o entidad a la que van dirigidos.
Si ha  recibido  este correo  electrónico por error por favor notifique al
remitente.  Este  mensaje contiene  información confidencial dirigida a la
persona  implicada.  Si  usted  no  es  esa  persona  no debiera diseminar,
distribuir o copiar este mensaje de correo electrónico.
More information about the FOSS-GPS
