[FOSS-GPS] Re: [Q] ublox EVK-6T setting for RTKlib (video capture
included)
julio menezes
yjmenezes at yahoo.com.br
Tue Jan 3 18:00:02 EST 2012
--- Em ter, 3/1/12, adioshun <adioshun at gmail.com> escreveu:
> De: adioshun <adioshun at gmail.com>
> Assunto: [FOSS-GPS] Re: [Q] ublox EVK-6T setting for RTKlib (video capture included)
> Para: foss-gps at lists.osgeo.org
> Data: Terça-feira, 3 de Janeiro de 2012, 13:21
> Your are my life saver.
> something is works. Thank you~
> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/file/n7147051/main.jpg
> Download(60M) : https://files.ucloud.com/pf/D49294_6848656_818585
> The upper left green box is blinking (input rover)
> However, the left main screen(Lat/Lon/Height) shows
> nothing
> also the output file full with empty result as follow.
> $GPGSA,A,1,,,,,,,,,,,,,,,*1E
> $GPGSV,1,1,0,,,,,,,,,,,,,,,,*49
I think you have to fix some lines inside rtknav configuration file.
Your video shows L1+L2 and 2000/01.
I apologise, I don't have a real Windows machine, but based on my tests under GNU/Linux, you can get some directions to fix your problem, I hope.
Please, skip some of my steps as your PC is talking with the receiver. :-)
Please, let me, or better us, know about your tests when you get it running.
good luck,
julio menezes
Type: application/zip
Desc: not available
Url : http://lists.osgeo.org/pipermail/foss-gps/attachments/20120103/f7a78290/ublox_rtknavi-0001.zip
More information about the FOSS-GPS
