[FOSS-GPS] RTKLIB SKYTRAQ
Grant Oswald
gkoswald at gmail.com
Tue Jan 17 15:53:36 EST 2012
Hi everyone,
I've been playing around with some of the skytraq receivers and rtklib.
So far I can achieve a fix (short time) using the moving average solution.
Also I can get a very good float solution using just 1 rover and a external
rtcm correction over the internet. I don't seem to be able to get a fix
between 2 skytraq's using 1 as a base station. Everything is communicating
ok.
Also I'd like to try having the rover receiving information from the
skytraq base station and using the cors network as a corrections input. How
ever the cors network likesw to be sent a nmea signal to respond with data.
I can only do that using the base station input, which stops me using the
skytraq base station.
Also I usually get more than 6 satelittes showing green in rtklib on the
base station and rover.
I'm wondering does anyone have a working example using the skytraq
receivers and wsuld they like to share that example for a rtk fix.
Thanks
Grant
URL: http://lists.osgeo.org/pipermail/foss-gps/attachments/20120118/9668519d/attachment.html
More information about the FOSS-GPS
