[FOSS-GPS] rtkrcv start command (rtklib 2.4.1) causes odd behavior to /dev/ttyACM0
Tshepang Lekhonkhobe
tshepang at gmail.com
Thu Jun 14 10:17:09 PDT 2012
On 12/06/2012 19:32, Tshepang Lekhonkhobe wrote:
> When I connect my EVK-6T device on my USB port, a file /dev/ttyACM0 is
> created, and I can run cat on it, which results in a bunch of NMEA
> messages on stdout.
> Not, if I run "rtkrcv -s" (rtklib 2.4.1), and then shutdown the server,
> I can't see the output from the file any more. The only way I found how
> to recover from that is either rebooting or running "minicom -o -D
> /dev/ttyACM0" and then just quitting it. Powering on and off the device
> doesn't work.
> Here's a 'graphical' illustration:
> wena at tshepang:~/src/rtklib_2.4.1/app/rtkrcv/gcc$ cat /dev/ttyACM0
> $GPRMC,171152.00,A,2609.09296,S,02757.78034,E,0.054,,120612,,,A*6D
> $GPVTG,,T,,M,0.054,N,0.100,K,A*23
> ^C
> wena at tshepang:~/src/rtklib_2.4.1/app/rtkrcv/gcc$ ./rtkrcv -s
> statup script ok
> ** rtkrcv ver.2.4.1 console (h:help) **
> rtkrcv> shutdown
> shutdown rtkrcv process ? (y/n): y
> shutdown script ok
> Here's the relevant part in my config file:
> inpstr1-path = ttyACM0:115200:8:n:1:off
> And maybe this is relevant too:
> inpstr1-type = serial
> Does this have anything to do with the config, or is it something else
> (e.g. my total cluelessness)?
> Note that this also happens if I set the module to only output raw ubx
> message.
This still happens, but it appears it's not an important issue, since
the device messages are still available to rtkrcv. Maybe the tool does
not do proper clean-up or something, who knows.
More information about the FOSS-GPS
