[FOSS-GPS] RTKLib MIPS requirements?
Danny Miller
dannym at austin.rr.com
Tue May 1 18:15:16 EDT 2012
STM32F4 "demo board" uses an Arm Cortex m4. 32 bit, 210 DMIPs and a
single-precision hardware FPU. I'm slightly unclear on the memory space
it has on this specific board but it should be 192KB SRAM and 1MB
flash. That's my porting plan.
If it WORKS, it'll be a great system, these boards are absurdly cheap.
It is several more orders of magnitude of capability than these 8bit
PICs and such, but I don't understand the scale of the flops requirement
of RTKLib. I know it's somewhere between "much more than any 8-bit
controller could ever do" and "won't even make Intel i7 break into a
sweat". And those are wildly different magnitudes. I don't know
exactly where RTKLib 10Hz would be between those.
And it's be running RTKLib and just some minor application (navigation
and monitoring) code which will not be processor-intensive, and it's not
using Linux or an RTOS. So there's not a significant overheat for other
tasks and the overhead's timing can be managed predictably and
accurately. Pretty much the core can either do it or it can't.
Danny
On 5/1/2012 4:43 PM, julio menezes wrote:
> Hi Danny,
>> I have a core with a hardware FPU, but it's only capable of
>> doing Single floats, not Double. It is going to break
>> things to implement the specified Double calcs with Single
>> precision? I would assume so, but it's worth asking.
> The RTKLIB author T.Takasu and A.Yasuda have ported RTKLIB to a BeagleBoard which has an ARM Cortex-A8- with 1 GHz and floating point, I do not know if double or single precision.
> I plan to move in this direction also, may be using a hardware less powerful but cheaper.
> Raspberry Pi
> http://www.raspberrypi.org/faqs
> The SoC is a Broadcom BCM2835.
> This contains an ARM1176JZFS, with floating point, running at 700Mhz, and a Videocore 4 GPU.
> I am waiting, anxiously, the RTKLIB 2.4.2 version with RTCM-104 phase messages encoder to built a local base station as where I live there are no near NTRIP network ( less than 10km ).
> good luck,
> julio menezes
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS
