[FOSS-GPS] rtklib: convbin in rtklib 2.4.1 does not work
Nick Østergaard oe.nick at gmail.com
Sun May 6 07:09:49 EDT 2012
Dear Tomoji
I am pretty new to this great rtklib,  but I have found that the
application program 'convbin' does not work properly in rtklib 2.4.1.
It works fine in rtklib 2.4.0. You should know that I am using it in
linux. Following is te output from convbin, where the sample file is
from lindi at http://iki.fi/lindi/gps/experiment/1/neo1.ubx.
The output if I use 2.4.1:
┌─[nickoe /tmp/rtklib_2.4.1/app/convbin/gcc]
└─ $ ./convbin /tmp/neo1.ubx
input file  : /tmp/neo1.ubx (u-blox)
->rinex obs : /neo1.obs
->rinex nav : /neo1.nav
->rinex gnav: /neo1.gnav
->rinex hnav: /neo1.hnav
->rinex qnav: /neo1.qnav
->sbas log  : /neo1.sbs
file open error: /neo1.obs
└─ $ ls /tmp/
roverlog1.rawlog        rtklib_2.4.1
roverlog1.ubx           rtknavi.conf
neo1.ubx
The output if I use 2.4.0:
┌─[nickoe /tmp/rtklib_2.4.0/app/convbin/gcc]
->rinex obs : /tmp/neo1.obs
->rinex nav : /tmp/neo1.nav
->rinex gnav: /tmp/neo1.gnav
->rinex hnav: /tmp/neo1.hnav
->sbas log  : /tmp/neo1.sbs
2010/07/26 08:03:18-07/26 12:58:54: O=17733 N=50 G=0 H=202 S=25055 E=1
└─ $ ls /tmp/
neo1.ubx              rtklib_2.4.0
neo1.hnav           rtklib_2.4.0.zip
neo1.nav             rtklib_2.4.1
neo1.obs              rtknavi.conf
neo1.pos
neo1.sbs
In 2.4.1 it does not output any files.
Sincerely
Nick Østergaard
More information about the FOSS-GPS mailing list
