[FOSS-GPS] Test file
Michele Bavaro
mic.bavaro at yahoo.co.uk
Tue May 8 17:24:31 EDT 2012
Hi Danny,
When you manage to compile RNX2RTKP for STM32F104 I will send you plenty
of files to test it against.
By the way, did you already consider the files in
rtklib_2.4.1\test\
Bests,
Michele
On 08/05/2012 21:25, Danny Miller wrote:
> Like I said before, I'm trying to compile RTKLib for the STM32F4,
> which looks like it may unfortunately lack the processing power, at
> least for 10Hz operation. That being something that needs to be
> determined.
> What seems useful to me is to start by running on data files instead
> of live GPS data. This would yield consistent results to work with as
> things are tweaked, and more important, won't run into problems where
> we overrun the input buffer because the processing can't keep up with
> the data rate. If there's an overrun error, it may be confusing as to
> what's actually wrong, and I wouldn't know just how far "under" it
> really was. If I'm working from a pair of log files that represent X
> seconds of data and it takes 1.5X seconds to process I know I'm short
> by that much. And it'll avoid the hardware the I/O setup too.
> Anyhow, is there a test file like that anywhere?
> Danny
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS
