[FOSS-GPS] rtklib ( no base station observation data for rtk
Mauro Ugarte Avilés
mauro.ugarte at cefop.udec.cl
Wed May 9 15:02:57 EDT 2012
Hi Willem,
Maybe you should try to test a simpler setup, by connecting the base
receiver directly to the pc running rtknavi, swapping both receivers, or
performing other minor changes until the observation data delivered by
the RXM-RAW message from the receiver acting as base gets showed and
processed by rtknavi. Did you set the fixed position of the base
receiver? which positioning mode are you selecting?
Mauro Ugarte A.
On 08/05/12 09:47, Willem Dantuma wrote:
> Hello All,
> I'am trying to make a base station + rover setup with 2 Ublox EVK-6T
> receivers and rtklib 2.4.1 all is going as expected thank to the great
> posts on this list. but now i having some trouble and always get a (
> no base station observation data for rtk message ) on the rover and
> never getting a FIX ( only SINGLE).
> This is my setup:
> Base station
> 1 ublox EVK 6T + rtkrcv on linux
> input 1 - serial
> output 1 - tcpsvr
> Rover
> 1 ublox EVK 6T + rtknavi on windows
> input 1 - serial
> input 2 - tcpclient
> Rover is connecting to the server fine and messages are send to the
> rover ( verified using the monitor in rtknavi ).
> Any ideas are welcome...
> Thanks in advance
> Willem
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
Este correo electrónico y cualquier archivo adjunto son confidenciales
y son solamente para el uso del individuo o entidad a la que van dirigidos.
Si ha recibido este correo electrónico por error por favor notifique al
remitente. Este mensaje contiene información confidencial dirigida a la
persona implicada. Si usted no es esa persona no debiera diseminar,
distribuir o copiar este mensaje de correo electrónico.
URL: http://lists.osgeo.org/pipermail/foss-gps/attachments/20120509/3fea17c4/attachment.html
More information about the FOSS-GPS
