[FOSS-GPS] Does anyone know that why RTKLIB does not support NMEA input?
julio menezes
yjmenezes at yahoo.com.br
Wed Nov 14 08:56:09 PST 2012
Yebin Lee,
John Morris is correct about nmea input.
I do not know your applications but rtklib can output their precise solutions in nmea format. Perhaps It can be useful for you.
regards,
julio menezes
--- Em ter, 13/11/12, John Morris <john at coyotebush.net> escreveu:
De: John Morris <john at coyotebush.net>
Assunto: Re: [FOSS-GPS] Does anyone know that why RTKLIB does not support NMEA input?
Para: "'Open Source GPS-related discussion and support'" <foss-gps at lists.osgeo.org>
Data: Terça-feira, 13 de Novembro de 2012, 22:46
"Raw" measurements include the distance and speed of each satellite from the
receiver. For each satellite, you typically get a "pseudo-range" and a
"Doppler shift" measurement. The GPS receiver knows the speed and location
of each satellite, so it uses the raw measurements to calculate the speed
and location of the GPS receiver. The resulting values of lat, lon,
altitude, direction and speed are part of the NMEA messages, but NMEA does
not include the original raw measurements.
RTKLIB uses a technique called "double differencing" which absolutely
requires "raw" measurements. The NMEA protocol simply doesn't include
pseudo-ranges or Doppler shift data, so it is useless for RTKLIB.
support raw protocol input
> instead of NMEA which is popularly used in common GPS receivers.
> Is there a reason for this?
This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20121114/0f4cfe1f/attachment.html>
More information about the FOSS-GPS
