[FOSS-GPS] I always get "no double-differenced residual" message with RTKLIB
Timo Juhani Lindfors timo.lindfors at iki.fi
Tue Oct 16 02:15:19 PDT 2012
Jochen <jochen.brunssen at web.de> writes:
> I use a LEA6-T as Rover with RXM-RAW and RXM-SFRB messages enabled and
> running at 5 Hz.
It would be really interesting to see the raw UBX data, would it be
possible to publish at least a small subset of it?
> array y has a maximum index of 19, the function always tries to read a value
> that is out of bounds, which is most likely 0. So the function validobs
> always returns false.
That sounds like a bug. Can you run rtklib under valgrind? Does it
confirm this?
More information about the FOSS-GPS mailing list
